SSR....Kind of Thick?
Beemerboy
Just One More Coat
Steve
The SSR 2.5 and 1 seem kind of thick, even after I have shaken it up quite a bit, is this normal?
It can be kind of a pain to work with because of that...can I add some water to make it a bit thinner?
Steve
they are supposed to be thick ..and no you can't add water, but you could add Pro Polish, PwC or some PwS and make a really nice multi-use polish ;)
Thanks Steve
I just have a hard time working with it when I can't get it to squeeze out of the bottle...
Try mixing the 2.5 or 1 with PWS i was playing with that for a little bit and liked it. By mix i mean put a thin ring around your pad with 2.5 then another with PWS.
Is it possible just the tip is clogged? Or do you mean once the product is on the pad its just real thick?
