It's a 08 Accord. Poor boy should I be using SSR1 to remove these light swirl marks?
Well - you can try the SSR 1 first with a polishing pad. If that does not meet your expectations, I would then try SSR 2.5 on a polishing pad. If that does not work, then it appears you might more than just light swirls. I would then go to SSR 2.5 on a light cut pad and the finish off with SSR 1 with a polishing pad.
polishing pad = white lake country pad
light cut pad = orange lake country pad
The only addition I will make to the above is do multiple coats of Blue!
With multiple coats of blue and then red,will the two mix and add gloss and wetness?If yes, how often can the two or one be applied? per week,bi weekly?
How about DAILY :rockon :bigups
:cheers:
. :cheers:
He's from Jersey, not Ohio. :rofl :notme:
j/k
I'm a wax waster.
You best not be taking a shot at me oh wasted one!.
assout:
