Spreading SIP
OCDinPDX
Paint Ph.D
In need of a bit of help here.
I'm presently plugging away on a black 2008 Acura TL and borrowed the Flex from a fellow detailer. He also loaned me his pads, Menz SIP, and Micro Polish. For the main polishing, I'm using the orange pad and the SIP but I'm having troubles getting it to spread thinly enough so it doesn't muck up the MF towels I'm using to remove it.
I've cut the quantity down considerably, even going so far as to put two small dots on the pad and it still spreads out way too thick, even after seven or eight passes with the pad. Any other ideas? I don't have this problem with the Micro Polish on the white pad.
Thanks.
