Spray/Rinse Sealants - Effects on your Tire Dressing Routine
mobiledynamics
For those using Spray/Rinse Sealants, do you make it a routine to clean/dress your tires a DAY before, if you are planning to do a spray/rinse application. I`ve done it both ways, and have not noticed a issue with dressing the tire after a spray/rinse application.
Kurious to see ones experience either or.
I use Tough Shine & HydroFoam to clean wheels. TS isn`t a regular "dressing" - but the HF works beautifully with it...
OP was meant to see if it was on anyone`s radar that you *must* or preferred way is to dress it prior, just in case the spray/rinse sealant mitigated how good or bad the dressing adhered to the rubber.
