Spot cleaning between wash
jeffdal
Hi everyone,
I need some help from the pro's........ What product would I use to do some light touch up spot cleaning between washes.....I am really only looking to clean water marks, some unlucky bugs, and around the wheel wells and rims..........Or is it best to just always do a complete job and wash the car?....Thanks in advance.
This is for a new 911
Jeff
Any quick detailer used with a decent microfiber towel should be able to handle the job. the water spots, if new, should come off with a shot of QD and then a quick pass of a mf towel. for the bugs Id lay a moistened mf towel over them for a few minutes and then they should wipe away (again, only if they havent been sitting there for days on end). for around the wheels, I'd tread lightly. alot of grit and grime can accumulate there just from daily driving. If it looks to bad for just a towel and some QD, id wash that those parts regularly (or with QEW if u have it) and qd the rest of the car.
Sounds like you need QD.
You can try Meguiar's Quik Detailer, or #34 Final Inspection. They work with just about anything and are easy to find.
If you start using a particular wax or sealant like UPP or Zaino, then you can switch to their QDs. Just about every brand has their own QDs.
