speedfreak81
Had the pleasure of meeting up with a member from M3post this past Sunday to do some work on his gorgeous Space Grey M3. He had some areas in mind he wanted me to address, specifically some scratching on the rear bumper from contact with a concrete wall. I also found some scratching, which you will see in the pics, in the carbon fiber on the roof.
He didn't want to go full on paint correction because the car is a DD and we've still got nasty weather coming. After going over options, we decided on a wash/clay/spot correction/sealant exterior detail.
Products Used:
The M3 as it sat when I arrived. Space Grey is nice because it hides dirt quite well.
Wheels, caked with brake dust
Sonax Full Effect wheel cleaner sprayed on liberally and allowed to sit for a few minutes
Clean!
Clay was pretty filthy
The M3 getting taped up
Scratching and clear coat dulling/defects along the rear bumper from contact with a concrete wall.
After correction
Upon washing and drying th roof I noticed a couple deep scratches. I was able to remove them with multiple passes.
After correction
Here is a 50/50 shot from the passenger side. I tried as best I could to capture the swirling, but I need a better camera. You can see swirling on the left side, and right side has been corrected
AFTERS:
Best Regards,
Brian Lewis
703-945-0629
Products Used:
- Sonax Full Effect wheel cleaner
- Dawn super concentrated dish soap
- Pinnacle XMT Speed Clay
- Poorboy's World QD as clay lubricant
- HD Uno on LC CCS Orange pad
- HD Uno on LC CCS White pad
- HD Poxy
- Stoner's Invisible Glass
- Armor All tire gel
Clean!
After correction
After correction
AFTERS:
Best Regards,
Brian Lewis
703-945-0629
