Souveran over AIO or SG
Do you prefere Souveran over AIO or over AIO and SG
  • AIO then Souveran
    Votes: 0 0.0%
  • Total voters
    9
firefli
I just curious, I've read about Souveran over AIO and also over SG. I'd like to hear some opinions about which way you prefer. Souveran paste over AIO or Souveran after AIO and SG?
Thanks in advance for you replys!
for the winter time I would use the souveran over SG...depending on where you live. souveran is a beauty wax...IMHO it doesnt have a long protection lifespan. So I guess what I am rambling on about is I would use it over the SG.
This is so subjective, here's what works for me, others in the colder north mostly seem to fall on the SG side of the question. I quit using SG when topping w/a good wax and would skip it in your case since you're in SO CA.
Here in GA, with garaged cars, I don't get any benefit from SG that I can notice. The initial gloss and pop is gone after 7-10 days with AIO-topper looking just as good with the topper as AIO-SG-topper, and durability hasn't been a problem for me as 3-4 months is all I go without polishing again.
I do top with wax every 45-60 days, after regular washing. I use P21S shampoo and believe this has something to do with miniminzing marring, giving a just waxed look each time, and getting good durability (at least good enough).
personally, I say pile the SG on as many layers as you choose and top with Souveran. I believe that layering SG or any sealant is time well spent, and topping with a good carnauba is just icing on the cake!
I would do souveran over sg over AIO. It depends on what you are looking for. If it is durabiltiy, then just use the SG. If it is looks, then go for the Souveran. If you want them both, then use them both. Just use the wax over the sealant. Your reading should have told you that sealants won't bond to waxes because of the oils. Its like painting a greasy wall.
