Sonus SFX Polishes and Pads Review
I received one of the promotional kits including all 3 SFX polishes and all 3 SFX pads. I held off on this review to give me a chance to try everything a couple of times. Cars used on: '97 Acura Integra - Dark Blue & '04 Acura TSX - Dark Grey
SFX-1 Polish: This is definitely an agressive polish, and has noticeable grit in it when you first apply it. I primed the pad first with QD (Meg's FI) and went to work on the hood of my older car (still shows some effects of my Pre-Autopian days). The SFX-1 polish in conjunction with the SFX-1 pad (a cutting pad) definitely removed some marring and scratches that were in my hood, and left noticeably marring of it's own like most aggressive polishes. Overall, I'd say it works well... BUT... the polish is extremely difficult to remove. I tried using more polish, less polish, working it longer, working it shorter, using LC pads instead of SFX-1 pads, nothing made a difference. The residue this stuff left was like glue. Spraying some FI on there and trying to remove made little difference. The only thing that ended up working was some AIO, but even then it didn't come off easily. The temperature was about 55 degrees one time I tried it and 45 degrees the other time. I was not working in the sun. Frankly, I'm stumped, I tried every different thing I could think of, but this was the most difficult product to remove that i've tried (some of the other polishes i've tried: 1z upp, pp, mp, 3m PI-III RC and MG, DACP, #80, all are easier to work with).
SFX-2 Polish: Used in conjunction with the SFX-2 polish, did a good job of removing the marring left by the SFX-1 polish, and produced a nice gloss. However, remember when I said that SFX-1 was the most difficult product I've ever tried to remove? I stand corrected. This stuff is worse it seems (or else I'm just getting frustrated by this point). I tried it on another car to see if it's car specific. It did work a *little* better on my other, newer car (I didn't want to try the SFX-1 on my newer car as it doesn't need it), but it was still extremely difficult to remove. Again, I tried a lot of different techniques. Working longer definitely is the right way to go (when I tried working it for less time in order to make it easier to remove, I ended up not working it long enough and I left marring when I tried to remove the product), but it's still not easy at all to remove the residue that's left.
SFX-3 Polish: Leaves a nice gloss, I will admit, but is no easier to work with than the other two. I didn't spend a lot of time trying to work with this.
Note on the dusting problem that's been mentioned before: I did not have this problem. In fact, I found it to produce very low amounts of dust. Not sure why. :nixweiss
Overall Impression: They produce nice results, but are not user friendly at all. I would probably score them at 2/5. That may be a little harsh, but they were so hard to work with and that outweighed the nice results. If you try them, and don't have the problems I did, then they'd probably work well for you. If anyone has any suggestions of anything else to try, I'd be happy to give it another shot.
SFX Pads: Good quality, velcro seems very firmly attached. I do have 2 complaints. First, because the velcro goes all the way to the edge of the pad, you have to make sure that the edge of the pad doesn't touch anything. This makes it much tougher to use the pad to buff odd areas like the tops of bumpers. I realize that this was done to make sure the velcro was attached better, so I guess it's a trade off. Second, the pads are very firm, even the finishing pad. This means that you have to apply more pressure to ensure full contact with the paint. Especially when applying LSP's, this isn't something that I want to have to do. I would probably score them at a 3/5 right now. If they soften up a little over time, and the velcro stays attached, that will probably move to a 4/5. I'd still like to try the Sonus DAS pads, as that design looks a little better to me, but I haven't needed to buy new pads yet (still have a bunch of LC pads in good shape), so I haven't tried those yet.
John
I am glad to see you had one of the same problems (and the most major one) that I had. Very user unfriendly products.
mtodde is going to be down here this week and I think he is going to detail his parents' cars. I may give him the SFX polishes to try as I suspect he would have the same problems. Sometimes I think I am too critical and expect too much...
Nice review as well. I was considering buying this when I place my order tomorrow but I think I'll stick with what I have. I just have so much DACP left, and I have other things to buy other than detailing supplies now, that it won't be worth it to me. :)
I didn't crank it all the way up to 6, I did the majority of the polishing at 5. I worked it for a variety of lengths of times, in an attempt to make it easier to buff off the residue. I tried wiping it off while still wet, but the product wasn't broken down yet and I left marring from wiping the product off. I also worked it until it was dry, and the longer I worked it, the more dust I'd end up with, but I never got what I'd consider to be an excessive amount. The one notable though, was the fact that it never got easier to buff off the residue no matter how long i worked the polish. The longer I worked it, the less residue was left (to the point where you could just barely see the residue, 'cause the pad had buffed off most of the product already), but that residue was stuck on there something fierce.
I wondered if it was the weather, humidty, etc. when I tried again today, so after struggling with it for a while, I pulled out the PI-III MG to clean up what I couldn't get off the hood. Night and day in terms of ease of use. The MG dusted more, but the residue wiped off very easily and gave me no problems.
I really wanted to like these polishes, and they did produce a nice shine, but they are a bear to use, at least for me.
John
My friend turned me to this product and he loved it. His parents have a black Denali and it had swirls and oxidation. Of course fadded also. He said there was alot of dust, but he never complained about it being tuff. He used all 3. All he kept talking about how well it turned out and how he liked it better than 1Z. He's been doing this for about 10 years. The weather in Ohio has been the same, 60 to 55 degrees. The panel might of been colder though. I was always told never do it below 40. I should get to try it this weekend with the long weekend.
I have alot of respect for your review and I am no way knocking it. I'm just telling you his experience. I'll tell him yours and see what he says.
audipower,
Glad to hear it worked well for your friend. There has been one other positive review so far besides your friend's, so the products are definitely working for some people. I'd be inclined to think I'm doing something wrong, if it weren't for the fact that I've never had this problem with any other polish, and once I finally got frustrated and switched to 3M, I had no problems. We should have 5 more reviews coming from others who got the promo kit, so hopefully we get some more feedback.
FYI, since you mentioned 1Z, those are still my favorite polishes, and the easiest to work with that I've tried.
John
This saturday I'm going to be using all three SFX's on a black eclipse. I hope to God I don't have the problems you did. Any suggestions on what I should do if I start getting gluey polish? I'm going to use this other reviewers directions and see how it goes. I'll update you Saturday night.
Just to clarify, the polish didn't get gluey while working it. Up until it came time to wipe off the remaining residue, I was happy with how things were going and how long it stayed wet/workable. I thought everything was going fine until i tried to wipe off the residue, and couldn't.
John
AIO got the residue off, most any chemical cleaner probably would have worked too. IPA might have worked but I didn't have IPA outside with me at the time and I did have AIO. QD (specifically Meg's FI) didn't work.
John
