Desertnate
Active member
...and jumped into the more advanced paint coating world by applying CQuartz UK to my daughter`s car. Other than using a sample of the standard CQuartz on my wheels, I`ve only used the original Blackfire coating (a disaster) and the McKee`s 37 (so easy, no one can get it wrong)
Overall the project went pretty well and served as a great learning experience for me.
Here are some observations. Many are probably old news for the experienced pro`s here, but hopefully they will be of use to lesser experienced members like myself.
Despite the favorable experience, I`m even more torn when it comes to coatings. I know there are some on the market which better in several areas when compared to CQ UK, but the 24 hour cure time and the expense for something I`ll only keep on the car for 12~18 months is difficult justify (espicially with Gyeon raising their prices). I might look at others like TAC Systems, Gloss Shop Ceramic, or Fenylab Ceramic Lite which seem to be similar to CQ UK in the future, but until then I`ve got a can or CanCoat calling my name. At least now I have the expience!
- CQ UK was very grabby or sticky when being applied. This took me by surprise since since the normal CQ was so easy. I immediatly had flashbacks to the Blackfire coating nightmares, but in this instance the level of effor to apply the product remained consistant and I became more confident as I worked the car.
- I had never really seen a coating flash in person before. It was interesting to see and everything people talk about and the videos all make sense.
- Looking for high spots was very hard in good lighting on gray metallic paint. I can`t imaging how hard it is on silver or white!
- The suede buffing towel which comes with the CQUK was a royal pain to use. A low nap MF towel is much easier for removing highspots
- I need to learn to let things sit and don`t mess with it if I don`t see a high spot. The CQ UK took a REALLY long time to flash/start drying and instead of simply letting it cure, I kept tying to buff it out when it wasn`t needed, which led to more corrective work. This is no WO/WO coating!
- I probably applied the product too thick which led to the long flash/curing time. I used nearly 20ml on a Mazda3 hatchback.
- Good ventilation is really important. The weather was really windy, so to keep the dust an pollen out of the fresh coating I kept the garage door closed. I`m surprised I didn`t get loopy from coating vapors.
- I really like using the MF suede swatches on a foam block to apply a coating. It`s a much smoother and even distribution than using an applicator like the one LC sells.
- 24 hour curing time is REALLY hard to deal with when coating a daily driver.
- CQ UK produced a really nice shine on metallic gray paint; almost as if the car recieved a fresh clear coat. The gloss was noticeably higher than the freshly polished pannels. McKee`s 37 coating in my eyes never looked much different than 845, but CQ UK really looked good.
