Smoke removal from apartment?
imported_Dude
The tires on my Jeep squeal like banshees when turning. Is this normal? I use the stock Goodyear Wranger RT/S tires. They have a raised, fairly agressive tread pattern.
My guess is that the treads are causing the tires to squeal, but I am not sure.
Also, when I come to a stop, my front tires often lock up for an instant, start to skid, and then go back to normal. This happens even if I am stopping very gradually. If I really try, I can stop without locking my front wheels and causing the skid, but it's very difficult.
Anyone have any ideas as to what could be happening?
If so, have the transfer case mechanism checked. If it's electronic, could be a bad sensor. If mechanical, may just need adjustment. If it's two wheel drive, then I don't have a clue.:p
I have a friend who can smell smoke coming through from the vents or something (non-smoker). Wanted to know what can be used to get rid of the stench (which is the best deodorizer for smoke?) thanks
The whole place has to be clean up ( if it was a smoker there before ) Carpet, walls clean or repainted, and A/C system clean out and maybe getting or using a ozone generator.
