SIP and Dusting
ptim
Can the dusting while using SIP be kept at a minimum, is there anything it can be mixed with. I like the results from using SIP, but I don't like the dusting.
been discussed a lot recently. think some mix a couple drops of Optimum Polish and/or prime the pad with a spritz of water/QD. I use Intensive polish and it seems to dust once the afternoon heat sets in. It's not so bad in low heat/low humidity.
