Single Stage metallic?
SilverSeven
Hi there all. Just wanna know if their is any thing as a single stage metallic paint? :nixweiss
And can a red / white single stage paint be coated with a clear coat? My painter told me that red / white cannot spray a clear coat on top or else the color will turn yellowish? is this true? :nixweiss
But I saw him spray a car the other day. The metallic color was matte in color, then when he sprayed a clear coat on top the whole paint was wet look shinning? So if that's the case When he sprayed red color the paint is already shinning....? :dance
Thank you kindly & Happy New Year.
Yes,single stage metallics were used right up until the early/mid 1980's.The customer usually had the option of,single stage,or two stage metallic(clear).
When you saw your painter spray a car,and the metallic color was matte,this is how it is supposed to look.The clear coat gives the metallic paint its shine/gloss,without it,the paint will appear dull,lifeless.
Oh okay. Thks it really clears up for me. Coz then my first car the Mini Clubman was a single stage metallic. I use to polish it so often till the paint cracked. And I see red color under the metallic blue......hehehe.
SilverSeven- I have two ss metallic cars at present, the '84 RX-7 and the '85 XJS. Gotta be pretty gentle with that paint, it won't take much polishing.
Spraying clear over a single-stage is tricky and can lead to problems. Not "will" but "can". Generally, if you want clear on there, get it shot is basecoat clear and have him put on a few extra coats of the clearcoat.
