The car is a 1989 porsche with (I believe) single-stage alpine white paint. As far as I know the paint is original. I'm most curious to know what the issue I'm seeing with the paint is called. Lots of photos I've seen show fuzzy reflections due to all the fine scratching, but this is almost that the surface looks 'lumpy'.
I tried to get a couple of pictures without too much luck. The first one shows the slight haziness of the paint. I had to put that water bottle cap on the hood to get it to focus.
http://i.imgur.com/KW4zxQX.jpg
The second one is a reflection of the light fixture in my garage. It has a knockdown ceiling texture which doesn't help here unfortunately, but hopefully this picture shows that the haze isn't quite as bad as the first one.
http://i.imgur.com/ZnNSMdn.jpg
I've clayed the hood and got next to no dirt on the clay.
Next I tried a few passes with Menzerna power finish polish with a white lake country flat pad (on a griot's DA polisher). It didn't look any different after this so I then tried Menzerna super intensive polish with an orange lake country flat pad. This also didn't have much effect. When I removed the tape, I noticed the paint seemed a little darker in the area I'd polished, but the surface quality/reflection was unchanged.
Am I going about this in completely the wrong way, or is this just not something that can likely be corrected very easily? The car looks clean enough and ok, but if I can get a clearer reflection in the paint that would be very nice.
Since the polish and car are both white, I'm a bit worried that I can't easily tell how much or how little paint I'm removing with the pads.
Any advice would be much appreciated.
