Should I Clay
Marty
I clayed the car about 2 months ago.
I am going to use a PC and some DACP to remove some swirls/scratches.
Would I need to clay the car again?
The car has not been properly hand washed for about 2 months but 95% of the time it is garaged.
There really isn't too much harm in claying again as long as you don't use a piece that is loaded with grit from the first time you clayed it.
In 2 months though the paint probably didn't get that rough.
It all depends on your local driving environment and how much fallout you get, so I'd do a check. If it needs it, just do it.
Marty- As Intel486 said, there's no problem with (gently) claying again. You might be surprised what has got on your paint. Claying can ensure that nothing nasty and/or abrasive contaminates your foam pad when using the DACP.
