Share your Detailing Procedures
detailbarn
Professional Detailer
I did a car the other day while my shop is being remodeled and all my stuff is a mess so nothing was where is was suppose to be. So I had to make trips back and forth to find what I needed. In doing all this I realized how important my rountine is in being efficent. So I'm looking to see if I can't improve or just hear what others are doing. I'd like to hear from Pro's as well as everyone else. When you set out to detail a vehicle what is your procedure , interior first , vacuuming or dusting , or the exterior do you clay when you wash , lets get down to the nitty gritty. Spill the beans , share the details on how you detail...... ok I'll shut up and listen now.
PS . Mobile Detailers please share your procedures too , setup to clean up.
Thanks
__________________
Doug Lucas
The Detail Barn
Here's what I do:
1. Pull car into the shop and pop the hood open so heat disapates
2. Examine the entire exterior of the car for defects and evaluate what the car needs
3. open the doors and trunk and evaluate the interior
4. come up with a game plan of what I need to do and assign a time allowance of what needs to be done to be profitable
5. Remove all trash and personal belongings from the car and discard or store for later.
6. remove all interior pieces (ashtrays, etc.) that come out, clean them and save for later
7. remove floor mats and set to the side
8 vaccuum interior, floor mats, and trunk
9.clean all interior surfaces except for leather or cloth, carpets and windows
10 clean carpets and cloth
11. clean door jams and trunk jams
12 clean leather
13 wash windows
14.use dressings and protectants
15 close vehicle up and prepare for exterior
Exterior
1. detail engine
2. clean tires, wheels, and wells
3. wash vehicle
4 dry vehicle (also dry door jams again)
5 re-evaluate any changes in process due to washing vehicle and time it out as necessary
6 perform fist step through last except paint sealant
7 spray tires with tire spray, and wheel wells with trim spray along with any other plastic trim, avoiding as much overspray as possible.
8 apply paint sealeant
9apply dressing as needed
10 clean windows
11 wax or polish wheels
12 open hood and dry remainders from engine detail. Also any compound or polish splatter from edges
13 remove compound or polish from door jams
14 re assemble interior if dry at this point ( usually is)
15 inspect the entire vehicle and perform any touch ups as needed
Hope this helped
1) Pull out floor mats
2) remove all ash trays and any other pullouts / floor matts
3) Remove garbage and keep in small bag
4) Remove small personal items and store in bag
5) Large items ( coats etc) I put asided till later and then I fold and lay on seat or in trunk where ever I found them
6) Vacumm int & trunk
7) I use the Woolite mix and a MF to go over the dash/controls/consil/door panels and clean the leather
8) Apply cleaner to tires and wash
9) Wash car
10) dry
11) Blow water out of hidden areas
12) examine paint and put a little piece of blue painters tape on spots that need attention
13) mask off trim
14) polish out trouble spots
15) polish car
16) apply sealant
17) clean all door jams/ trunk edges
18) Dress tires / wheel wells
19) dress rubber mouldings
20 ) wash windows
21) lift hood and wipe edges ( I don't do engine details as yet .. drainage issues )
22) Inspect
23) Place bag of personal belongings on floor in pass. front.
