Scratches on rear lights of car - advice needed.
qwik
I have a few scratches and blemishes on the rear lights of my 02 t/a, i guess from crappy towels and carelessness when i am not with it. I went to the plastic care section of properautocare.com to look at products and alot are for plastic films on headlights or plexiglass windows, now i was wondering what i could use (by hand) to remove lines, swirls and a few blemishes. I have a few pictures below but they aren't great, hard to see in my dark garage and there is crap all over them because of the rain, but any advice will help. I am not opposed to using a machine, i don't have one, but i can get one. I would rather do it by hand though because there is a painted on bird on the back rear filler panel that a machine would surely damage. Thanks
pic1
pic2
Try Plexus. Spray on, wipe off. You can find it at most any motorcycle shop.
It's not a miracle worker, but it's a good product to start with before trying something else with a machine.
I used the wetsanding method on a set of extremely yellowed headlights on our van.
1. Tape off around lights
2. Wetsand the lights
3. Plexus buffed with a wheel in a drill.
Sad that I did not have Before & After Photos.
Results were wonderful.
Do a search here.
I have used Simichrome polish(MC Shop) on tail lights and dash lenses. I know it's a metal polish, but it worked on the plastic. The last instrument cluster lens job that I did, I used Meguiar's # 17 Clear plastic cleaner. It made the lens look new. I did the work by hand. I rubbed perpendicular(across) to the scratch, instead of with the scratch. Use a non scratching cloth(MicroFiber) or your finger, to work out the scratch, then a final wipe with a MF. It worked for me...
As you can see i have scratches aswell as some marks that look like they could have been made if something hit the lenses say at a garage or bodyshop, someone bumped a tool or something into it creating a blemish, will that meguiars plastic thingy work with that too? Thanks.
4DSC where in vancouver did you purchase the Novus #1 and #2 and for how much? (On your link there you said you got it at some plastic shot :)) Can you also use this product on the plastic covering the speed gauges?
Side note...what online sites do most of you recommend buying detailing products from? (i'm in canada if that makes any difference..TIA).
qwik, The Meguiar.s # 17 Clear Plastic Cleaner is what I used to "Tune Up" the tail light lenses on my Eldorado. They look new now. The other day, I was doing my wife's Riviera with Meguiar's # 20 Poly/Sealant, and I did the tail light lenses with it. They look sharp. Before plastic polishes came out, on the market, I would use a mild cleaner/wax product to remove scratches from plastics. It's not really rocket science, to remove scratches on most things. If you polish out the scratch, by going across it, then going across in the other direction(once the scratch is gone), the surface will become flatter (Straighter) and flatter. Deep scratches-heavy pressure and/or an agggressive compound. As the scratches diminish, vary the pressure(of application)and the compound, till you get a scratch-free surface. You can do it!
I purchased mine at Industrial Plastics and Paints in Richmond. I can't remember what I paid for Novus #2, but I think it was $8-9. I haven't used it on any instrument covers yet, but it should be safe.
I hate mail ordering stuff :p but the Autopia store worked for me and ships USPS too. I think CMA does too, but I'm not 100% sure of that one.
I've used Novus #2 & #3 on a lot of plastic lenses. I've found #2 is very adequate for most scratches, and have used it on instrument clusters with amazing results. Also use it on my Maxima's headlights to remove scratches/yellow hazing, and on tail and corner lights for scratches. Best plastic polish I've used (although I haven't used Plexus, and have heard good about it). Novus #3 is intended for deep scratches, and works extremely well for them. But you'll need to follow with #2. From a Novus bottle, you can call 1(800)548-6872 for the nearest distributor. I paid about $5.00/bottle at a local plastics shop in Louisiana.
If the scratches aren't too bad, and you're in a pinch, you can use a SMR like Megs #9. Works well for light scratches/swirls on plastics.
Dave
I just tried Novus #2 and #1 and the tail lights of my car look newer and not as faded now :up. Also used both on the instrument cluster and it looks great :)
Glad it worked for you. I know on my car it made a huge difference going from 10 year old hazed up taillights (covering the whole trunk!) to clear taillights again. :)
