scholl shampoo
PA DETAILER
DETAILED TODAY?
:D
used this morning.
scent...really none.
color...off yellow.
size...500ML
i used this product as instructed on bottle. i did not use the foam gun or in a bucket.
products used....
shampol
groits MF wash mitt
bucket with grit guard
WW drying towels
on to the application. rinse vehicle with water. fill up the bucket with clean water. soak your mitt. apply directly to the mitt and procede to wash your vehicle top down. rinse you mitt out several times in the water bucket.
rinse vehicle off with clean water. your done.
i DID NOT notice a sheeting of water as stated (lotus effect). but i do have 2 coats of max wax and prima hydro max on. :inspector: same as using my usuall megs hyper wash as far as the final rinse. cleaning ability was very good. and the mitt just glided over the paint. good lubricity. where this soap really produced was when the paint was dried off with WW towels. :bigups it states it leaves a polymer protection behind. it does indeed! the paint looked great and glossy after the final drying. you will not need a QD or spray wax after using this soap. at $17.99 it's not a cheap soap. interesting none the less. and the first soap i know of that you use this way. i would be safe to say results would not be the same if used in a gun or bucket? if your looking for something different, this is it.
http://www.autopia-carcare.com/scholl-concepts-shampoo.html
Wax and sealant shouldn't be a problem. At least in my mind
Cool review thought, thank you for saving me the $$$$ :)
for sure. if you have a good wax/sealant on, it will not interfer with it. it will only add to the gloss/protection. its really a interesting soap.
Thanks for the review.
It's to bad the soap did work quite like it is claimed to.
The only other soap that I know of that applies the soap to the wash pad is IronX soap.
