I am thinkinf of going out and buying a rotary to apply Zaino's ZPC Fusion.
I've done some searches, and many say that you need a Rotary buffer for results because applying it by hand wont cut it.
Then when reading the directions for ZPC, it says
Will an orbital provide any results?
If it is recommended I use a rotary, would this model cut it?
All the rest are $199+, which I will not spend.
If an orbital will get any results work, I kind of like this one.
I really do not want to ruin my paint in any way, so if the consensus is dont try it yet, I wont. I can tell you, the sticky in this section freaked me out some against trying it.
To make things a bit more complicating, I do have black paint. I use the full line of Zaino as well.
Here are a few shots of my SS.
For experienced users? Should I stay away from the rotary then? Or just be careful on the edges of the car?# For MACHINE use: Can be used by random orbital or (for experienced users) rotary. Select a moderate speed (RO - 4.5; Rotary - 1200rpm) and an appropriate cutting or polishing pad. Apply Zaino Z-PC Fusion to the buffer pad in a "star" pattern. Start machine slowly to reduce sling. Work a small (2' x 2') area with moderate pressure until satisfied with results.
