Jngrbrdman said:If the area is uncleared then I don't see what the point of putting a sealant on it would be. Other than maybe making the water bead up on the paint under the hood or something... Its really not going to do an awful lot for unclearcoated surfaces as far as appearance goes. ... I'm sure you could use it, but I don't really see what the benifet would be.
Accumulator said:I take the opposite view on this one. I polish and then REALLY seal the rough, un-cleared areas, trying to make up for the factory's shortcuts. It keeps these areas cleaner and less likely to retain moisture. Much easier to clean, too, compared to scrubbing stuff out of the rough texture. After a few years, the benefits are much more noticeable than they are at first, cumulative effects and all that.
