Pats300zx
Super Moderator
I decided to pick up a bottle of the S100 Shine Enhancing Paint Cleanser today at the local Harley dealer ($8.95) and give it a try. This product (per the lablel) is designed to remove minor swirls, oxidation, etc , and is a prep (paint cleaner) to to their S100 wax.
I have been using Pinnacle Paint Cleansing Lotion (PPCL) on the 300ZX for a while. I found the S100 to be much easier to use than the PPCL. It went on much easier and was a breeze to buff off.
I tested the S100 Paint Cleaner on the front bumper area directly under the center panel area. I figured it was a good test area based on the wear and tear the surface gets.
I clayed the area completely and followed up with the S100 Paint Cleaner. The stuff is great. It left the surface as slick as can be and removed some of the minor swirls. I then followed up with the S100 wax. I plan on putting another coat of S100 on in 24-48 after it has had time to cure. The surface looks great.
I would highly recommend this product. For $8.95 you can't beat it !!!! Thanks to Scottwax for the tip...:up
