S100 over Zaino... method?
2rocky2
I have read a lot about this, and there's no real method listed for the application.
How do you guys do it?
I was going to do this:
Dawn Wash
Claybar
Dawn Wash
ZFX
Z2
Z6
(repeat ZFX 3 times)
Then top it with S100
Am I right in this, or is there more to it, in either the Zaino application OR the S100 application?
I appreciate any help you can give!
Edit: Which S100 should I buy? I have read of two different products so I'm not sure which one... both are available at Harley dealers right?
If you haven't already, do a search on "Nick T". He wrote up a really good outline of his tips and tricks.
I did the same thing but used Z5 and Z2. Just so I'm hearing you correctly, you are going to use ZFX and Z2 together...right ? From the way it's written, it can be interpretted differently.
This is what I've done:
Dawn
Clay (lube is the key)
Dawn (some say you should use Z7 or regular wash instead)
Z5/ZFX
Z2/ZFX
Z5/ZFX
Z2/ZFX
(with Z6 in between each step above)
I haven't topped with S100, so I can't comment from experience, but a lot of people here say they've had great success with it. The S100 is at Harley shops or online for about $15.
For removal, I started with the 100% cotton towels that Zaino recommends. My towels were still new the first time I did it, so I had a lot of lint. So I switched to MF towels without any problems.
Good Luck
Oh....it's a beautifull thing. Just make sure you give atleast a day before topping the S100 over the zaino. I got a new cam, so I'll show you my results.
It made my car look a little wetter and reflected color a little better. It made my car look whiter (it's a white car)
94NDTA,
Looking Sweet !! :xyxthumbs
What was your paint prep ? Clay, polish, etc.
How many layers of Z did you use and did you only do Z2 ?
Alcohol wash (old zaino removal)
Clayed
DACP on hood
#9 on the rest and on hood
Dawn
Z1
5 coats Z5 w/Z6 between each coat
8 coats Z2 wZ6 between each coat
3 coats S100 waiting 1-2 days before each coat and Z6 between each coat.
I am very pleased with my car. I was wondering if Z6 is too strong of a QD to use between coats of S100?
