Using a PC, geekysteve's article says to use a yellow or white CMA pad and to use horiz/vert/diag motions for about 5 minutes at a 3.0-4.5 speed to break down a swirl remover (#9 or SMR) on a given panel.
If one were to use a ROTARY with the same pads and the same swirl remover:
Q1: do you use a figure 8 or E motion or the h/v/d method?
Q2: about how many minutes do you work the sr say at 1000rpm's?
I have never used a rotary but one of my friends is asking me. Thanks.
