Rotary Pads
Miami_Sunset
I just bought a brand new Makita but im looking foward to buying new pads.
( whats better curved edged or flat ? )
the Makita comes with a Hook & loop, which i believe is a velcro, if so should i still invest in this flexible one ? what do you guys recommend.
6" Hook & Loop Rotary Flexible Backing Plate
autogeek_1870_16437078
Curved Edge Full Contact 7.5" Foam Pads
autogeek_1871_9847009
What size is the backing plate that comes with the Makita?
I picked up a CE rotary and it came with a 7" backing plate, being a noob with a rotary I didn't feel comfortable with using 8 1/2" pads so I opted for a 6" flex backing plate and 7 1/2" VC pads.
I like how the plate has just that little bit of give when I am going over an uneven surface.
HTH
"J"
the Stock Makita velcro back up pad 7' inches but does a flexible yellow pad from autogeek make any diffrence compared to the one that comes from makita factory. ? will it affect performance.
I bought the flexible BP and Wolfgang pads from autogeek and they work fine for my rotary. The only pads I have that are flat are the ones that are exactly 6 inches-- the curve around ones. I would recomend the Wolfgang or LC pads that curve around.
