You should be able to get the desired results using your PC and M105/M205. Just remember to prime the pad well. Add a ring of polish around the pad and rub it into the pad with your fingers. Make sure that there is enough polish to completely cover the pad. After you have primed the pad, take a MF in one hand and place the PC with the pad onto the MF and turn it on at speed 3 while holding the MF on the pad. This will remove any excess polish. Once the pad has been properly primed, add three small sized drops onto the pad and with the PC off, rub it onto a 2 x 2 area. Then turn the PC on to speed 3 and spread the polish. Once the polish has been spread into the area, turn it up to speed 6 and use enough pressure to slow down the rotation of the pad, but not stop it. Clean your pad after every section, and change pads often.
Good luck.
