former86camaro
Well, I was anxious and wanted to test out my new rotary. (Chicago Electric from Harbor Freight) I have; No say I had some swirls I needed to get rid of and this was the time to use it. I used 3M SMR for Dark Colors followed by WG Pre-cleaner by hand and Sealant by hand. Looks great. My buddy came over and noticed the hood right off the bat after just using the 3M SMR and nothing else. Here is how I did it:
1.Rotary Slow!!!!
2. Used Detail Mist to “wet� the pad because I heard a dry pad is dangerous
3. Made my X shape on the pad with the 3M
4. Only let the machine weight be used and actually I lifted evenly off a little to remove a few ounces for safety.
5. Worked small 2 foot areas only and stopped the rotary once it began removing some of the stuff and used a MF for the rest.
6. Pre-Cleaned with WG
7. Sealed with WG
8. May top with #26 not sure
What I noticed. SLING SLING SLING all over…It is a powerful tool and should be used with caution. I did try to remove the swirls by hand with the 3M SMR and even 1Z products and never really removed them until the rotary.
I now need backing plate and pad recomendations..I am looking for non aggressive to appy 1 z paint polish and 3M SMR and #26
1.Rotary Slow!!!!
7. Sealed with WG
