Reviewed: EDGE Wheel ShMitt
justin30513
Mobile Detailing Services
I recieved this Wheel Shmitt last week and wanted to give some time in the field before posting a review. I've used it on over 20 wheel and tires of various shapes and styles. It is just as comfortable as my Wash ShMitt. I have not once dropped it or had it slide off my hand. It comforms to all types of wheel styles getting in grooves and crevices. I've noticed it "conforms" and takes on a shape to mold into the size needed to clean. When it comes to tires, it cleans them more effectively than any brush I've ever used. It easily travels into the wheel well making it a snap to clean them up. The ShMitt's large pores cause a nice foaming action to occur. Clean was so easy due the large pores also. Mine was air dry in one hour. If you do not want to use harsh chemical to clean with, this product will aid in cleaning with you normal wash water.
I recommend this product 100%.
The ShMitt holds so much water....
Getting into the grooves....
Foaming up....
Even gets into the lug-nut holes....
Hopefully this isn't too far off-topic.
Would the Wheel ShMitt be a good tool to use with Poorboy's Spray & Wipe on wheels and either S&W or an APC on tires?
Charles
Charles
The pores are too big. You would want the yellow/white mitt here.....
