Reviewed: EDGE Wheel ShMitt
justin30513
Mobile Detailing Services
I recieved this Wheel Shmitt last week and wanted to give some time in the field before posting a review. I've used it on over 20 wheel and tires of various shapes and styles. It is just as comfortable as my Wash ShMitt. I have not once dropped it or had it slide off my hand. It comforms to all types of wheel styles getting in grooves and crevices. I've noticed it "conforms" and takes on a shape to mold into the size needed to clean. When it comes to tires, it cleans them more effectively than any brush I've ever used. It easily travels into the wheel well making it a snap to clean them up. The ShMitt's large pores cause a nice foaming action to occur. Clean was so easy due the large pores also. Mine was air dry in one hour. If you do not want to use harsh chemical to clean with, this product will aid in cleaning with you normal wash water.
I recommend this product 100%.
The ShMitt holds so much water....
Getting into the grooves....
Foaming up....
Even gets into the lug-nut holes....
Hmm...I have been looking for something like this.
I am curious...when I detail cars, I usually spray with water, then spray with a Wheel Cleaner (Meguiars Wheel Brightner) and then go at the wheel with a sponge or something to agitate the brake dust. Could I use this product as a replacement for the sponge?
I try to be careful with anything I use to clean wheel wells due the large amount of grit that can be picked up there. If I'm following your technique, you at least use the Wheel Shmitt on wheels again after it has been cleaned (if you do all the wheels and tires then go back to the wells), or worse, go from wheel/tire to well back to wheel again. Can you elaborate a bit more on how well this device cleans up and what likelihood it has to retain hidden grit that might scratch wheels? It would be hard to see since the device is black.
*I* wouldn't go dipping my hands in Wheel Brightener. Sooner or later, that's going to hurt!
:werd:
I would use brushes in conjunction with Wheel Brightener to keep my hands away from it. Even then I would still probably wear rubber gloves. Wheel acid is not healthy for you.
Mikeyc said:
:werd:
I would not use it with WB either. It's more for maintained wheels. Brightner should be used with a brush.
Agreed.
a friend has these shipped into the uk the wheel mitt is good but i aint impressed with the schmitt for the bodywork.
Justin...
How is the mitt for cleaning tires?? Can you clean the wheels and tires together with the SMitt???
Pats300zx said:
Justin...
I did.
Scrubbed the tires better than anything I've ever used. For real. Got into all of the grooves and treads.
Since you posted this statement, could you back it by telling us why?
So more can be informed and not make uneducated conclusions.
Since you are now taking issue with other people's opinions, could you clarify whether you have paid for your Shmitts (wheel and body) or if you have received them from the manufacturer for free in exchange for your feedback?
Now this is singling someone out. All I asked for was the reason.......bad or good and you have to start showing your butt off.
I do this for a living.....100%. I wash more cars in a week than most wash in a year. I've used every wash utensil there is. I wash 5k cars to 200k cars. The ShMitts are the best that I have used. I don't push them onto anyone or bewilder them for using anything else. I just want them as well as you to have a freak'n open mind and not trash a product that you have not tried. If you have, just tell me why you didn't like it. Maybe it was user error or just a bad product.
Yes, I have recieved 2 ShMitts.........a grand total savings of 20.00 out of my 500.00+ per month budget. Woohoo. Not enough to sway to brag on a product if it was not worth it. I was buying 2 wool mitts per week. The one wash mitt got 100 uses........easy. Save me over a 100.00. So really it made me money.
Mama told me if you ain't got nuttn' nice to say.....stay out. If he felt he needed defending, I'm sure he is big enough to handle it himself.
