The Guz
Mike
I received this as part of this giveaway.
http://www.autopia.org/forums/autopia-carcare-com/184073-dirty-microfiber-pads.html
I had a few pads laying around that needed to be cleaned. These have been sitting dirty for a few weeks now. I completely forgot about them until I saw them again today. Perfect timing to try out the foam and pad cleaner and my first ever Poorboy's product.
Here is the bottle I received. The labels were damaged on arrival as one of the products leaked in the bag.
Angus if you don't mind, I am borrowing your photo to show the directions on the label
I washed these pads by hand since I didn't have that many to clean. I sprayed it onto the pad and let them soak for a few minutes. I worked it in and rinsed the pads out with warm water.
A Meguiar's foam pad before and after. This pad was used with an interior protectant. I believe it was Blackfire.
Here's a Rupes blue pad that has Zephir compound on it.
There is only water in the open celled foam.
Here's another Rupes pad that had Keramik polish on it.
Finally this last foam pad was used with Adams leather conditioner.
Overall the foam and pad cleaner did an excellent job cleaning out the pads. The scent reminded me of black licorice. It's tolerable unlike some APC's. It left no residue in the pad as far as I can tell as the product rinsed out fairly easily. Next time I will use it with the other method of soaking the pads in water and a couple ounces of the foam and pad cleaner.
