The Guz
Mike
Just a quick review of this product. I have used it a handful of times to clean my pads both foam and microfiber. Each time it's worked very well.
The directions state to let the pads sit for 15 min prior to agitating. All one needs is one scoop in 3-4 gallons of water.
I let these sit overnight after I finished the last paint correction as it was pretty late.
I came back the next day and used my fingers to work out the polish residue. It removed with the residue with no issues.
The only thing that it didn't remove was Meguiar's white wax. That was a little more difficult to remove. It did keep the pad wet so the wax didn't dry onto the pad. I had to use other measure to remove White Wax from the pads I used it with.
Other than that It does a very good job of cleaning pads. I tend to rinse them out with warm water just to be sure there is no left over residue from DP. I'm just a little OCD like that.
I recommend it.
Here are the before and after of this 3" pad
After
I recommend it.
After
