Review: (4) Turbo Wax products
ZaneO
*NOTE* I received 2 oz. samples for evaluation purposes.
Product: Turbo Wax car shampoo
Price: $9.95
Manufacturer's Claim:
TURBO WAX CAR SHAMPOO with its slick gentle suds safely removes dirt and grime without removing waxes or sealants. Especially formulated for today’s painted and clear coated finishes. This highly lubricated formula with its unique foaming quality and quick rinse characteristics safely lifts dirt and grime while helping to prevent swirls from washing.
* Safely removes dirt and grime
* Formulated for today's finishes
* Quick Rinse formula
* Safe on your hands
Packaging: N/A
Color/Scent/Viscosity:
Usage: I used approximately one ounce of car wash solution in 1.5-2 gallons of water. I sprayed a strong stream of water in the bucket to "suds it up." I then washed the car in my normal two-bucket method using a Eurow sheepskin mitt.
Overall Thoughts and Notes: The soap had decent lubricity and cleaning ability. Overall it was effective, and once the vehicle was cleaned and dried, it left a nice finish and added a slight amount of slickness. I would compare cleaning ability to that of P21s soap, but the final product was not quite as good.
Product: Turbo Wax Paint Protection
Price: $15.99
Turbo Wax Products Choice and Best Seller! Highly Recommended! Once you try this product you will be amazed at the show wining award look! This product is for real! By far the best paint protection that we have found in the market!
Turbo Wax has created this unique water-based tri-polymer emulsion that shines and shimmers like the finest of carnauba based waxes while having the durability of a polymer sealant, Turbo Wax Paint Protection is formulated especially for todays exotics and sport compact cars paints, Turbo Wax uses the best ingredients in the market, creating the best blending of a polymers for a high gloss finish, Turbo Wax its one extraordinary polymer wax.
* Deep Shine
* Formulated with Polymers
* Safe for all car finishes
* Specially formulated for today's exotics and sport compact cars
Packaging: N/A
Color/Scent/Viscosity: It is purple in color and a bit thicker than I'm used to. The scent is a light chemical smell.
Usage: I applied to a vehicle freshly washed with the Turbo Wax Car Shampoo with a new foam applicator (primed with a squirt of Turbo Wax QD). I applied it very sparingly - a dime sized drop per panel. I allowed it to dry/haze for about 20 minutes and removed with a clean microfiber towel.
Overall Thoughts and Notes: Application and removal was easy/smooth. The finish was very slick and had a deep, wet appearance. I monitored the durability - beading, gloss, slickness, etc. were pretty much gone at the two month mark. Overall, it had a good appearance and is very user-friendly. Durability was less than I like to see but still decent.
Product: Turbo Wax Last Minute Detailer
Price: $12.95
Turbo Wax Last Minute Detailer was formulated especially for that important moment when time is of the essence, Quickly produces a slick and wet glossy appearance while extending the life of your paint sealant, removes light dust and finger prints without scratching your paint.
* Produces a show look appearance
* Easy to Spray on and wipe off
* Wet Glossy look
* Safe for all paints
Packaging: N/A
Color/Scent/Viscosity: Light orange color with a pleasant scent.
Usage: I applied 1-2 squirts per panel to the freshly washed and waxed paint and buffed dry with plush microfiber. I also used in the same fashion on other vehicles and on different waxes/sealants.
Overall Thoughts and Notes: It's easy to use and streak free. It adds some slickness and gloss to waxed and unwaxed surfaces and can be used on glass, chrome, etc. Overall, it's a nice QD, but it didn't give me anything I haven't had before.
Product: Turbo Wax Tire Care Gel
Price: $13.95
This unique gel formula clings to the tires surface, unlike sprays and foams that end up on wheels and painted body panels. Four Star Ultimate Tire Protectant Gel also prevents premature sidewall dry rot and cracking.
Boost your tires look with Turbo Wax Tire Care Gel while adding long lasting protection against premature dry rotting, this gel formula is easy to apply and reduces sling off.
* Restores the richappearancee
* Protects and shines
* Non-Sling Formula
* Long Lasting Protection
Packaging: N/A
Color/Scent/Viscosity: It is a clear, semi-thick gel.
Usage: I applied a moderate amount to a clean tire swipe and spread evenly across the tire.
Overall Thoughts and Notes: The gel spread pretty easily and dried within 20 minutes. The durability seemed pretty good...about 2 weeks, but I would expect that from a gel. It left a semi-glossy finish on large sidewall tires. Overall, pretty good dressing (if you like gels).
Purchasing
: www.fiber-works.com or www.turbowax.com
Nice review Zane :xyxthumbs
Can these Turbo products be found locally?
Looks like you used "GSR formatting" for your review...lol :chuckle:
Thanks, all!
Johnny - Yep, I asked Sean a while back if I could borrow the format. I think it's excellent for allowing a completel review.
Scott - I wasn't aware that these were OTC products... :nixweiss I didn't note any cleaning ability, but there wasn't really anything on the paint to clean.
I'm sure I have seen Turbo Wax products at auto parts stores. :nixweiss
Price: $13.95
I think you meant to put Turbo Wax Tire Care Gel, not Four Star Ultimate Tire Protectant Gel. ;)
Nice review. The H2 looks great. Did you use any polishes/cleaners before the wax?
I copied the text straight from Turbo Wax's website :)
The H2 didn't really need anything before...it only had ~1000 miles on it.
I guess I can say this over here since its not DC.
I have used 4* and Turbo Wax both. I think they are pretty much the same thing, hence the name and affiliation with each other. Even the wording is identical between the 4* website and Turbo Wax website.
I found the sealant to last around 5 months while garaged. It was slick and beaded well. I used it over the pre-cleaner.
The tire gel is outstanding IMO. It spread and sticks great onto ANY tire.
They have 4oz products for sale pretty cheap, and 4oz of a sealant lasts me forever, i will order some and check it out.
White95Max said:
Oh. I found it odd that Four Star's name was in a description of a Turbo Wax product. I guess you were right then!
Somebody should fire the copy editor! Go post that over at the other forum!
Nice review Zane, thanks for putting it together. But, I'm skeptical about this review - aren't you one of those guys that "do not register as who they really are, but try to influence people to buy their products in very subtle ways..." :chuckle:
