The Guz
Mike
I picked this up as part of my purchase at the local 3D store. Decided to put it to use and to distract me a little after getting home yesterday seeing the results of my dad's Camaro stripped. It's like losing a family member. As well as my grandfather who is having some health issues.
Product link:
3D Liquid Leather
Product Description:
Cleans, conditions, and beautifies leather in one step.
Now with Mink-Oil to give an extra softness to leather.
Gentle on leather.
No greasy residue.
Liquid Leather is the fastest way to clean, protect and beautify the leather interior of your vehicle in one simple step. This gentle leather cleaner not only gets your leather looking like new again, but it supplies the leather with special UV inhibiting polymers designed to prevent premature aging and cracking. With our latest advanced formulation including pH-Balancing agents, you can be sure that this protectant matches the pH Balance of your vehicle’s fine leather. This will keep your leather hydrated preventing leather from drying, thus saving expensive leather restorations down the road. Now fortified with mink oil and neat’s foot oil which will enrich your leather just like many of the high quality tanneries have been using all around the world for decades.
This All In One leather cleaner/protector is perfect for leather seats, leather dash boards, and leather arm rests as it gently cleans deep into the pores of the leather’s finish removing harmful dirt & soiling. With every use, you’ll restore and retain the natural non-greasy suppleness of your leather.
Liquid Leather is great for most types of automotive leather and should be used to maintain its perfect appearance from day one. This product will prevent premature cracking in high wear regions such as side bolsters and seat bottoms and will reduce abrasion to the leather’s external coating each time you enter and exit your vehicle. Liquid Leather’s water-based properties dry to the touch and will not leave any greasy or sticky residue behind that will promote resoiling. Use as often as you would like, there are no detrimental ingredients in this product that will harm any part of your leather. In fact, with regular use you will build up a barrier to block out UV degradation and blue jean dye transfer all while offering water repellency too.
Liquid Leather is also great for cleaning and protecting synthetic vinyl seats and plastic trim too such as dash boards and door panels. Like leather, these items are susceptible to ageing and premature cracking so using a product like Liquid Leather will work great on these items too. It will not cause any slipperiness to your interior components and will leave the surface looking clean and naturally vitalized.
Product video courtesy of 3D:
Front of the bottle
Directions on the rear of the bottle
It's a bit hard to tell with the lighting but the product is a white gel like consistency. Similar to Meguiar's D181 Leather Cleaner and Conditioner and HD Protect.
I used a microfiber applicator to test out the cleaning ability of the product.
50/50 on the lower part of my chair. This is right after application.
I applied it to the remaining section. I came back with a microfiber and lightly buffed it. It gave a matte like appearance.
There was some dirt removed from the chair. It was not a whole lot as I hardly sit in the chair.
Initial thoughts:
I am going to give my initial thoughts until I actually use it on the interior of a car. I can't put my finger on it when it comes to the scent. It's almost like a leather type scent. It is very similar to HD Protect. It did go on very easily and a little product went a long way. Especially once the pad has been primed with product. It appears to be doing some cleaning action. For those of us that regularly maintain our interiors, this would be more than enough for an AIO. It is non-greasy. It did not leave a sticky feeling. The shine can be controlled.
So far this looks to be like a good product.
It says it can be used on all interior surfaces, so I am looking to use it like that.
For $8, it's worth giving it a shot.
Product link:
3D Liquid Leather
Gentle on leather.
No greasy residue.
Front of the bottle
Initial thoughts:
