Removing Zaino
ahunt01
Ok, I know i've seen similar posts like this, but I still have some questions.
I need to remove all the Zaino from my car, since it's getting re-painted soon. I've heard that there is an "ABC Wash", and an isopropyl alcohol wash that will do it. I've also heard of using a mildly abrasive car polish but I don't want to do that since I've got to get the car re-painted.
What is the "Abc Wash"? What's the process/steps?
What is the process/steps of the isopropyl alcohol wash? Again, process/steps?
With the isopropyl alcohol wash, I'm assuming that I'd wash the car first to remove dirt, then do the isopropyl alcohol wash, and then re-wash to remove the alcohol?
If the car is being repainted, the body shop will take care of cleaning up the panels; you shouldn't have to strip any products for them. If they're not cleaning the panels with a good solvent first, then I'd be wary of having my vehicle painted there . . .
That said, alcohol's probably the easiest way to remove the Zaino. Mix a 50/50 solution up in a spray bottle. Spray down a panel, let it dwell for a minute or two (re-spray if it starts to dry out), then wipe down with a MF towel. You can also find "prep-solve" at auto paint supply stores; it's a paint safe solvent that will strip oils, wax, sealants, etc. Same idea as the alcohol . . .
Tort
Ah ok, I thought I had read somewhere that I need to strip Zaino off, because the body shops don't do it properly. I might have read that in one of Dave's online guides awhile back.
After I spray with 50/50 alcohol/water and let it sit for a minute or two and then wipe off, should I wash the car? If so, with what? Will Zaino be ok to use to wash the car, or should I use something like liquid Dawn?
Yeah it sounds harsh to me also. Normally, I would have no reason to strip Zaino off my car, but since I'm getting it repainted I'm not that concerned with my factory clear coat.
Ray said:
Alcohol on your paint? My body man said it's very bad for your clear coat!
And he's wrong, at least for the dwell times we're talking about. 50/50 alcohol and water, used in the manner described earlier in the thread, is not harmful to modern paint that has cured completely. That said, if you're concerned about alcohol, then you could use a paint-safe "prep-solvent" that's intended for use in a paint shop. IMO, though, the solvents in the prep-solve are much stronger than a 50/50 alcohol solution.
Tort
Megs APC+ at 64:1 will strip wax. I'm sure it will also remove Zaino in same ratio, but you could increase the amount.
Just spray and wipe off. Wash the finish and you should be ready.
Regards,
Deanski
I still will let them prep the surface. But let's face it, most people now days cut corners. I know I take more pride in the way my car looks than any local body shop, so I'll make sure every nook and cranny is prepped properly, which I doubt the body shop will do. I mean it's a business, and to make money you have to do the job semi-quick, so it's possible to miss something during the prep work.
I've read that Dawn Liquid Detergent will strip Zaino with ease. I agree that a good body shop will take care of the prep but I see no problem with doing all I can do prior to them getting their hands on it. I'm sure I would take this small precaution first. :cool:
No, Dawn will not remove Zaino, Dawn's only purpose in the Zaino process is to strip off regular waxes before your first coat of Zaino so the Zaino can stick to the paint as Zaino will not adhere to other waxes..
Just a question, are you getting your entire car repainted?
I don't use Zaino but have a friend who is a 1st rate Zainoid. He and I go the Meguars/Zaino rounds all the time. He swears Dawn will strip it.
Then something is wrong, I work with Sal all the time since 1998 and used Zaino since 1997 and I know one wash with Dawn will not strip it....
My advice to you is if you have the time try to strip it. My biggest fear would be fish eyes in the paint, especially those that do not appear until after several months.
I agree with the others that its the body shops job, however, in reality how fanatical are they going to be?
I had a repaint that went back to the shop SEVEN times, so if you can do anything to avoid any future aggravation its worth it.
GOOD LUCK!!!!!!!
