wifehatescar
My L5-S1 is killing me!
Anyone else do this much? Seems like everyone goes right to an abrasive instead.:huh
Recently I've been doing some rotary work with IP/polish pad and then a chemical polish like Adam's Revive on a finish pad. I usually get 1/2 circle swirls from the IP but the Revive takes them right out. Does anyone see a reason to use another abrasive like FPII instead of a chemical polish? I assume the Revive was acting like a lube and the finish pad was actuially doing the cutting (on a rotary even a finish pad makes heat)
