Removing Sticky Rubber Adhesive
sexmoneydrugs
I've had a hardtop on my Jeep for the last 3 years - it required 2 strips of insulator rubber adhesive to be applied.
Is there anything safe that I can buy from a local shop that I can use to remove the residual rubber and goo that were left when I pulled off the adhesive? It's on top of a painted, clear-coated area of my Jeep.
I probably should have checked here first before I even tried to pull off the adhesive - so any help would be greatly appreciated.
Hi - can I get those at an Autozone or a Wal-Mart?
Thanks very much for the quick replies - as I live in a rural area and am going into the "big city" today :) The big city basically having a Wal-Mart :)
sexmoneydrugs said:
Hi - can I get those at an Autozone or a Wal-Mart?..............
I think I've seen the 3M at Wal-Mart in the auto section near the touch-up paints and Bondo.......... if not there try near the tapes and glues.
sexmoneydrugs said:
Very cool - thanks very much. I'm out to the big city :)
Watch out for the loose women that hang out in those big cities :chuckle:
And as BigJim posted, I have very good luck with WD-40 too.
I couldn't find the 3M stuff, only the WD-40. Are there any precautions I should take, or is it safe on paint? I take it I just take a paper towel and try to rub it off? I have some Cobra microfiber towels, but those things are stupid expensive.
And Miss Kitty says her girls ain't loose, ain't loose, ain't loose... but the echos convinced me otherwise :)
sexmoneydrugs said:
.......only the WD-40. Are there any precautions I should take, or is it safe on paint? I take it I just take a paper towel and try to rub it off?..............
Test it on a small area first, but it has always been paint safe for me. I'd try to use a cheap MF or small cotton towel, you can try a paper towel but it might not work as well. You might have to let it dwell for a little while to dissolve/melt the adhesive residue.
