Removing Spiderwebs by hand
jfteague
Hi all. I'm new here at DC and also pretty new at detailing. I just got my first black car (2005 Dodge Ram QC). I had heard from several people that Zaino is great so I bought their kit so I can keep the truck looking good.
Well I finally got a chance to use the products and as I was using the Z-5 polish I noticed several spiderwebs all over the finish. Being a new truck I wouldn't think it would have them already but it does. I've seen some black cars in person that don't have a single imperfection and I want to know how to get that!
Can anyone recommend a way to remove these by hand? I don't think I have the experience to pick up a polisher like a PC yet. Last thing I need is to ruin the paint or clearcoat. Is there another polish that works before I continue with the Zaino products?
I appreciate the help!
Some of the Poorboy's SSR line is said to be somewhat "hand use friendly".
Removing spiderwebs/swirls can be done by hand, but it is a lot of work.
The PC would make things a whole lot easier and your concern about experience with a PC is not necessary. The PC is so easy to use that you would almost have to try to cause damage to get in trouble with it.
Just use good, clean pads with products that are meant to be used with a DA polisher and you should be fine.
Charles
ScratchX would do it for you. You'd want to get a couple tubes if you want to cover the whole car. You'll also want to set aside a day or two to get all of it done, and have a cooler filled with ice water waiting for when you get done and you feel like your arm is going to fall off. It'll work, but it would be easier if you got a PC, it's a great investment that will serve you well for years.
hand removal is a hell of a task. i tried it on a small area(6"x6") sometime back on a friends car witih some SSR2. it proved to be too much effort for ok results. i ended up pulling out the PC and redoing the area. i can't imagine doing the entire car. you'll be investing in beng*y stock!
you should have no fear using a PC. the machine is extremely user friendly and for the minor marring you want to fix, it's the perfect machine for it.
i did it on a dodge ram by hand with some IP and a terry towel, then the IP with a mf towel then i did FP and a mf and it worked for me.
Thanks for all of the replies! It sounds like to get the results I want I should get a PC. I have seen vehicles that are flawless and look like you could use them as mirrors! Is this just the picture or do they look like that in person? I'm willing to put in the time since I understand that once it is done it will be protected with the sealants. I want my truck to look like it drives around wet and also is protected from these scratches in the future. Am I asking too much?
Regarding the PC, is there more than one model?
Thanks again for the help. I've learned quite a bit about detailing just lurking around here!
I think Jay was referring to Menzerna's Intensive Polish.
jf.... There are a few different models. For the Porter Cable (PC) there is the 7424 and the 7336, basic difference is the counter weight (one for a 5" and 1 for a 6" plate.) There are also other brands of Dual Action Polishers. Porter Cable is just the most "famous" on these boards.
"I want my truck to look like it drives around wet and also is protected from these scratches in the future."
Also, not to rain on your parade, but even after a paint job is "perfected" the protection from a sealant is more in terms of protection from UV degradation, not "bullet-proofing." Poor wash techniques, inconsiderate/uninformed people touching the dusty finish, and even everyday driving can cause cob webbing, swirls, scratches etc. to appear. It's a constant process, not a one time fix.
Let me assure you that you can handle a PC. I got mine a while back to use on my jet black BMW 328i. I also bought some Poorboy's SSR2.5, SSR1, EX-P and Natty's wax. I did the whole routine on a ratty Geo Metro, thinking I would need to get the hang of it for a while. Being a 21 year old girl, the most heavy duty tool I use would be a hair-dryer. Half way through my first panel on the Metro, I couldnt wait to do my own car. Metro looks like a brand-new 8 year old car. You can do it! :bigups :)
That's good to know Palamino! I'm sure it won't be a problem but I will probably follow your lead and do a practice run on my commuter car. I'm sure it could use it anyways.
Did you buy yours locally or over the net? I see your in SoCal - whereabouts? I'm in Orange County.
