Remedy for small after an interior fire ...
Oxen72
What would you guys suggest for removing the smell from a near-new car (2-seater, 2017 model w/ 1500 miles) that had a small interior fire?
Background ... the passenger seat bottom was set on fire. Heat/flames got the headliner & visors - mostly just singing the fabric layer. The drivers seat wasn`t flamed - but fabric layer singed pretty good as with the headliner. Interior cabin got hot & smoky, but damage was isolated to plastics & fabrics. Carpet was heat damaged behind the drivers seat, but going to replace it just because its likely holding odor.
So far, I`ve literally gutted the "entire" interior ... nothing left but wiring & the air control box. I`ve wiped/washed all surfaces that I could reasonably access (tough job). I`ll do the same to all the "reusable" trim panels, including the dash panel.
As of now, with the interior out, the "burnt plastic" smell is faint - but, still there. Plan on going 3,500 mg/hr Ozone for 2-hrs next ... but, wanted opinions before I deployed the "nuclear" option.
Poorboy`s makes an enzyme-stain cleaner for fabrics that might be applicable as a cleaner/deodorizer for this application BEFORE you try the ozone generator. They also make an orange-oil based all-purpose cleaner (APC) that may be more effective as a cleaner of vinyl or plastics to remove fire soot.
While what you are doing to clean this fire-related incident in a relatively new vehicle is a viable methodology, I would think the nuclear option of an ozone generator is probably your best option to removing fire odors if the enzyme cleaners do not work effectively.
I would be more interested in HOW this fire started on a seat bottom in the first place in a new vehicle. It doesn`t sound like it`s electrical and hence, a manufacturer defect that would be covered by a vehicle`s warranty. This sounds like a person-induced accident/incident that, I would guess, is just too embarrassing (or illegal) and will not be turned into the vehicle`s insurance under a comprehensive claim. The fact that it happened and how to deal with it is your concern.
I`d run the ozone a lot longer. I`d leave mine in there for a good long time, but it only runs ~890mg/hr. Heh heh, "nuclear option" is right! That Big Gun Ionizer you have (3800 is impresive) oughta make some great headway with everything pulled apart.
I agree with Lonnie, while everything is out of the car spray and leave Enzyme on all the plastic and fabric pieces ... a good cleaning afterwards with either APC (diluted) or Carpet and Upholstery cleaner
Edit*** Enzyme Stain & Odor Remover. How it works is it needs to come in contact with the source of the odor and the enzymes devour the source of the smell. It works on cloth seats, headliners, carpet, AC vents, anywhere you can get the Enzyme to contact a surface it will kill the odors.
I got it at auction (Copart) to repair; so, all that`s been handled. The how is a mystery ... passenger seat bottom was obviously lit, I found remnants of a burnt "phone book" there. Lighter was found under that seat as well. Drivers seat I just can`t understand ... top layer of fabric was singed; and, seat back burnt up maybe 1/3 the way. Additional oddness is that it obviously got much hotter on the drivers side than the passengers ... for example, I`ll have to replace the drivers door panel - but, the passengers is fine. Whatever the case, it had to be doused fairly quickly as nothing was totally "melted".
Literally gutted ...
VW had a problem with heated seats and a similar issue. People were getting burned, literally. Can`t say I recall an actual fire among all the stories, but you have to believe it`s entirely possible for that to occur.
"Burnt plastic" smell? I say just put it back together and tell whoever you are trying to sell it to that`s just "new car smell". Of course if you are fixing it up for yourself that won`t work...
Owen72:
Thanks for relaying the story of this incident and how you came to acquire the vehicle.
My initial post may have sounded a little "judgmental", since I made the (bad) assumption you were the original owner AND caused (or viewed) this fire incident.
What was/is even more telling about this assumption is the fact you have not revealed the make and model of this vehicle and you were/are embarrassed to tell us. I (perhaps wrongly), assumed it may be a higher-end vehicle, since it is a 2-seater. Anonymity does have its advantages.
Some of us (well, me in particular) are just plain nosy! As I say, "Inquiring minds want to know...."
lol .. Now that was a lot`a writing ... would`ve been easier to just ask "what`cha working on?". :) Didn`t initially mention as it wasn`t really pertinent to the smell/detailing question.
attachment.php
Typing without my glasses on!
You know ... I just realized that I titled this thread as "Remedy for small after an interior fire ..." :o
Should`ve read "Remedy for smell after an interior fire ..."
What I get for typing without my glasses on!! Thanks for the responses ... I`ll pick up some Poor Boy`s products as mentioned.
Re: Remedy for smell after an interior fire ...
Oxen72- Did you try the ionizer yet? I`m still marveling over how potent yours is :D
No; haven`t utilized it yet ... didn`t think the unit was very special though, just an el-cheapo eBay model. Maybe their stated specs are off?
Hmmm...maybe, though I don`t want to come across like I`m slamming it. FWIW, something legitimately in that output range would cost more than the ~$500? I paid for my little one.
Likely ... but, all things considered, I figured it was worth a try. This`ll probably be the only time it gets used; I`m not a commercial detailer so nothing like that is/was intended.
Some machines, I`ve noticed, are placed "outside" of the vehicle with like a dryer hose feeding the o3 air into the vehicle. This unit says to just place it in the vehicle - for no more that 30mins at that. Hmmm ... :huh:
WOW! I just looked at the picture (by selecting it of the enlarged .pdf) of the gutted interior. When you said gutted, you mean gutted!!
My hats off to you for your mechanical aptitude and prowess to tackle such a task. That`s a lot of work.
Any news on how you`re progressing on this fire-smell cleanup? (I was bewildered at the original title of small fire, until I read the post and deduced you meant "smell", especially when you included the ozone generator.) Are you replacing any thing, like seat leather covers or carpeting or headliners or door vinyl side/kick panels?
Also, did you find any thing "unusual" during this interior strip-down that was damaged during this fire, like wiring harnesses?
The remnants of "burnt phone book pages" thing and " obviously lit" sounds like fodder for a Farmer`s Insurance commercial! "Party goer`s Christmas Eve yule log fire. Yup, we covered it. December 24th, 2017 Queue music: We are insurance, da, da, da, da da, da..."
Oxen72- As long as you cover any rubber stuff (to prevent oxidation), you should be able to run it for a while. AFAIK that`s the idea behind time limits for such stuff. I`ve left mine run on Max for hours and hours with zero problems, but again its rating is way lower.
Well, I`ve surfaced cleaned everywhere in the "gutted" cabin as much as possible ... and boy is that a tough job! Afterwards, I`d say the smell diminished by 85% ... still there. I hung several small sacks of activated charcoal for absorption; but, the objective is to eliminate the source ... so, I`ll be ozone-ing this weekend to attack that remaining 15%. Smoke rises, so the majority of the soot was in the roof & pillars.
With the dash out, I inspected it & there was no damage. It retained a smell as well though; so, I detailed it with what I had on-hand while I awaited the Poor-Boy`s product. I`d say I got it 95% so far.
Anything along the pillars & roof area(s) was toast (no pun intended). The fire heated the interior pretty good, but I found no hidden damage other than the obvious ~ the seats, headliner, pillar trim, visors, drivers door panel, & smaller plastic parts took the brunt of it. The carpet will go as well ... mostly do to its ability to retain the odor. I`ve repaired several salvage vehicles in my day ... this was the first "burn", and "smell" is definitely the challenge. I wouldn`t have touched the car if there would`ve been panel damage.
Thanks; I`m going to hit it this weekend - not going to bother rigging a dryer vent hose. I`ll post the "smell" results afterwards.
Oxen72- OK, looking forward to hearing how it goes. Remember that ions fall down, so try to position it high in the interior (rear package shelf is my usual spot). I can usually close the door on the cord without problems and that keeps everything inside to do its thing. Eh, you already know all that...
Well, I can report back that I had success with the Ozone treatment ... no more smoke smell (from interior fire) whatsoever inside the gutted cabin. The generator suggested a 30-min treatment - I went for 45-mins. If anything, I should`ve went with the shorter time as I had a bit of a lingering ozone smell afterwards - the ambient temperature(s) being less than 60-degrees didn`t help either. Several days of airing out have eliminated it mostly. The little $56 eBay machine seemed to be worth it!
My Poorboy`s order showed up today, and I`ll go after some interior trim with the enzyme spray - odd thing was the bottle shipped without a trigger sprayer ... hmmm. Typical?
