You Lucky !!!!!!!!!!!!!!!!!!!!
I have also been researching them, and found my match here --
(you know what to type here)steam-cleaners-direct.com/
This unit is selling for $695 and free shipping, I believe and comes with alot of extra brushes, etc.. There is alot to read on this website about them, but I think if I could afford one, it would be this one.
Will try to find your choice and read up on it.
Think this alone inside the house and in the shop would be a great tool to have to allow cleanng with less chemicals, etc., and getting everything off easier the first time.
I have to assume the temps used could remove any sealant and maybe start a big problem with paint adhesion - especially on plastic pieces, which have a flex agent in them that makes them already easier to move around than paint that is adhered to metal panels, etc..
I would not want to use it on a vehicle's paint, but would be happy to use it in the house and interiors of vehicles. I think it would also be of great help in the engine compartment to a degree, again the higher temps you have to just be more careful with on some surfaces..
I already have a pressure washer that I use on engine compartments, etc., but of course it is not spraying hot water, and we all know that just hot water alone, makes any clean up easier for the most part.
When I was a kid working at my Dad's shop, we always used hot water to first start removing all the brake dust and grime, etc., that was on the brake surfaces, before we even started dismantling them.
Good luck with your purchase, let us know how it works, we are all green with envy now !!
Dan F
