Raymond mill is a kind of flour imported from abroad mill, more domestic production, it is prepared for all kinds of ore, coal preparation, such as raw ore, gypsum, coal and other materials, powder processing. Raymond from the shape look like a steel container to erect, with inlet, outlet and central parts of the feed port. MPS mill shape and some approximation. Raymond mill stick rotation axis is vertical, MPS mill grinding stick rotation axis is the approximate level.
Raymond mill lower part of motor driven internal grinding stick with the grinding disc rotation will need to crush or grind material through the inlet of the wind blowing finished materials, mill within the upper part of separator can be separated coarse and fine powder, and then through the adoption of Raymond wind out of the outlet from the collection.
Raymond works
Raymond mill works is under the centrifugal force roller tightly rolled in the grinding ring, scoop up material from the blade and the grinding roller ring sent to the middle of materials under pressure in the grinding broken into powder, and then under the action of the fan to blow up the material into a powder through the analyzer to achieve the required fineness of the material by analyzing the machine, who fail to return to the chamber to continue grinding the material into the machine through the analysis of sub-processor separation cyclone collection. Exhaust ventilation with a separation of industrial filter cloth into powder.
Raymond mill scope of machine is mainly used for barite, calcite, feldspar, limestone, talc, Whitehead, gypsum, etc.. Mohs hardness of less than 9.3 and humidity below 6% of non-flammable mineral products, chemicals, building materials, such as hundreds of high-fine milling of materials processing, product size in the range 40 ... 400 mesh arbitrary regulation. This series of products for different materials and different particle sizes, different output, etc., into high-pressure micro-grinding, extreme pressure suspended roller mill, Raymond Mill three series of ten kinds of common models.
Raymond works
