Quick Article: The different way to remove water spots.
Todd@RUPES
Just a regular guy
This is for a forum member who had a question on removing water spots, particularly with out the use of a clay bar. I thought the information could be relative to other members who had similar questions and he agreed to let me post a public reply. I hope this article helps.
First, there are two types of water marks, and how you remove them depends on which type of spot they are. I am quoting an article I wrote to identify the two types of water spots.
Todd@Autpia said:
A common question on this forum (and others) is how do I remove water marks from my paint.
Before we can prescribe a solution it is important to diagnose the problem.
Visible water marks generally fall into 2 categories, as illustrated below: Mark Spots and Water Etching.
Water Spots: Water spots are caused by evaporation of water droplets. Water is usually not pure and has some solid material that is left behind from the evaporation. Water spots are the solid remains left behind from water and they can adhere to the paint fairly strongly. Water spots should be considered contaminates or above surface paint defects.
Solution: If the water spots are fairly fresh then a wash with car soap and water can remove them. If they have adhered to the paint strongly or formed a bond they will be more difficult to remove. Wiping the paint with a chemical cleaner such as Chemical Guys Water Spot Remover will help loosen and remove them. If this doesn't work a clay bar, an All In One (cleaner/wax) or even a light machine polishing may be necessary.
Water Etching: Water etching is caused by a chemical reaction between the material in the water or the chemical make up of the water. Metal and calcium in the water spots, will over time, begin to eat away at the clear coat. This results in a crater, usually deeper along the outer rim, where the clear coat has been removed. Sometimes liquid chemicals in the water, such as high levels of acid (acid rain damage) can cause etching almost instantly.
The longer that water spots are allowed to sit on the paint and the more heat and sunlight they are exposed to, the greater the risk of them creating etching. Water etching is damage to the paint or a below surface defect.
Solution: The depth and severity of the water etching will ultimately effect the exact process that is used for removal. In the case of light water etching, a light machine polishing may fully remove them. With moderate to severe water etching the paint will likely need to be compounded or wetsanded to fully remove them. The best way to solve water etching is not allow it to take place to begin with.
The question of this thread is how to remove water spots, which as the article above describes as stubborn mineral deposits on the paint. Since this the focus of this article I will concentrate on their removal. Removing the other type of spots- water etchings- requires resurfacing the paint (either aggressive compound polishing or wet sanding) to repair.
The following are the common ways used to treat water spots.
  • Chemical Cleaning with a Water Spot Remover
  • Detailing Clay Treatment
  • Light Hand/Machine Polishing
  • Pre-Wax Paint Cleansing Lotion
  • All-In-One Cleaner Wax Application
Chemical Cleaning with a Water Spot Remover-
This is perhaps the least invasive method. For years people have used, and I have recommended mixing distilled white vinegar with water (1:1). Wash the car first then wipe the paint with the solution and let dwell for 5-10 minutes, then agitate with microfiber towel and rinse off. This works fairly well, and the ingredients needed (vinegar + water) is readily available. The down side is that it works 'okay' and your garage, car, and drive way will stink for weeks!
Another viable cleaning solution is Chemical Guy's Water Spot Remover. We are bringing this product into our store after experiencing first hand how well it removes water spots. I know several (extremely high end detailers) who have used this product to remove water spots plastic trim and cowlings!
Detailing Clay Treatment-
A lot has been written about using detailing clay to remove water spots and for good reason. It cleans most contamination off the paint's surface quickly. Detailing Clay can struggle with some low level water spots only because they have no real thickness. Detailing clay floats above a lubricant and abrades any contaminants that stick above the paint's surface. However many times enthusiasts have clay handy so it is a recommended treatment because it works often.
Light Hand/Machine Polishing-
Lightly polishing the paint with an ultra fine abrasive polish will scrub the water spots clean and well and increase the gloss and clarity of the paint.
For hand polishing consider Meguiar's Ultimate Polish.
For machine polishing team up a soft foam finishing pad (such as a Lake Country Black Pad) with a an ultra fine machine polish like BLACKFIRE SCR Finishing Polish or Menzerna SF4500 (the same exact polish used at the Mercedes Factory for assembly line refinishing as a last step for ultimate gloss).
Pre-Wax Paint Cleansing Lotion-
"Paint Cleaners" are a great choice for removing light water spots. Paint Cleansing Lotions are design to deep clean the paint and prepare for a fresh coat of wax. Many wax or paint sealant manufacturers make paint cleansing lotions that clean the paint and prime it for their wax/sealant. They use either a chemical cleaning solution or a fine polish or a combination of both.
The two best I have used are BLACKFIRE's Gloss Enhancing Polish or Utlima Paint Guard Prep
All In One Cleaner Waxes
Cleaner Waxes or AIO's combine a wax or sealant with the properites of a paint cleansing lotion. They are designed to clean the paint and protect it one, time saving step.
KLASSE AIO is a classic in this field, where BLACKFIRE Total Polish N Seal uses the latest in technology/advancements.
You can apply most AIO's by hand or machine. If applying by hand (like a paint cleansing lotion) you want to work into the paint with a foam applicator with a little bit of passion.
These are some of the options of removing water spots. Depending on your goals each can work. After using Chemical Guy's Water Spot Remover, I am excited to be adding this as an addition to our growing Chemical Guy's line up. It will make a viable cleansing option and should be available shortly.
Comments, questions, suggestions are always welcome!
:thumbup:
While not a Chemicals guy zelot their water spot remover is very nice. I still want to try out Optimums water spot remover that Fermani speak highly of.
I use CG water spot remover on my Opti coated car, makes it look nice again!
Cheers,
GREG
Cheers,
GREG
It is a great product! :bigups
Cheers,
GREG
Need to try this
