Questions on Procedues...
jstuckey
Hey guys!
Given that these are the products I will be using, which order should they be applied? Given that this is a new BLACK vehicle that has beeng garage kept.
Also: Any tips and other information that is vital would be appreciated!
I'll be sure to put up pictures after I have completed the processes I have learned here.
Thanks again,
JS
Nice line up of products. I would start out with the Slick wash and wash the truck . Do the 2 bucket thing , Soap in 1 bucket Clean water in the other. Do a clean water rinse of the wash pad before you go back the soap bucket. Then you can clay using S&W or the soapy water depending what you like. Next on to the SSR products , start off with 1 anf if that doesn't seem to give your the results your looking for step up to SSR2 . Remember your choice of pads to apply product and work it should be considered with this step. Next you could go right to EX-P followed by Nattys . You could use the Polish before the EX-P if your not happy with the look after SSR1. BTW don't clean your wheels and tires with the same water your going to wash the vehicle with save them for last along with the wheel wells . Good luck
