Hi guys. Sorry I couldn't find any thread that would fit in for this.. I just had my Mitsubishi Lancer 1992 EL carburetor cleaned today. Everything seems well, except for this: I noticed that the repair guy directly poured thinner on the carburetor while running my engine before a test drive. Before I went to their shop, my main complaint is that the engine really takes time to start and it suddenly stops while driving. At one point I had to pour gasoline directly to the carb so it would run. However this time around, the guy used thinner. I know he used it to clean the actual carb but is it recommended to pour it directly into the carb while the engine is on?? One thing I noticed too is that at one point today my car suddenly stopped again. I needed to push on the accelerator further to have it run smoothly again, though this happened only twice. Aside from those 2 instances, everything seems to be smoothly going. So that sums up to my main question, is it safe to pour thinner directly to the carb while engine is running? If not, what should I do? Should I have an engine oil change already and drain the gasoline? Thanks in advance..
