Question on UDM...
macconinc
I applying KSG with my UDM. I'm unclear as to how much KSG to use and how much area this amount covers ? Also, what speed on the UDM shouod I use to apply the KSG ? Last time I used 3.5, but it didn't seem to break the KSG down.
Thanks,
CJB
Using the UDM with KAIO is fine but I don't see any reason to use it for KSG. KSG is a nonabrasive sealant-there isn't anything to break down. Try applying it with a foam applicator extremely thin and use a wipe on wipe off immediately method.
hmmm... i guess i was wrong but i thought you applied and waited for it to cure then wiped it off... Ive only used it once but i have a BUNCH left of it. I need to use it up!
