Question on Bill North method
Blackmirror
I did a good amount of research and have an idea how to do this method. My question is when I apply the SG to say half of my hood, do I do one pass on a section with the MF pad or several times and then buff off right away?
I have been using a home made MF applicator and applying to about a sq ft then remove .. seems to be working just fine .
Blackmirrior,
Check your PM's as well. Your question here is more specific/makes more sense to me than in the PM.
To answer your question, you can go over an area more than once with the MF pad before buffing off. It all depends on the SG. Just don't let the SG get too dry otherwise it will be a PITA to buff off regardless of the fact that you are buffing off immediately.
Bill.
