craigdt said:What kind of wax are you using?
Typically, I use the applicator that came with the product. (such as a foam applicator). Then I apply the product as thin as I can.
jDizzle said:there are instructions on each can that should be followed. but generally you use an applicator thats either foam or cotton terry or microfiber over foam, dip it into your wax with a gentle wiping motion to get a small amount of wax on your applicator, then using a flat hand (not finger tips) and light pressure rub it onto your car in a thin coat, you should not see any white residue until it dries, it should be thin enough to be clear when it first goes on.. let it haze (dry), you can swipe your finger accross the paint with wax on it to see if its dry, its called the swipe test.. if your finger leaves streaks the was isnt dry, if it comes off clean its dry.. some waxes say to let dry, some say dont let dry, some even say let sit for several hours, it should be in the instructions. remove with a CLEAN microfiber cloth such as a viking microfiber from autozone, or a carrand microfiber from any autoparts store; orange vroom towels from target are rebranded carrand towels so theyre ok too.. use as little pressure as nessicary to remove the hazed wax. by the way, to test a microfiber towel, you can rub it on a cd, if it scratches, dont touch your paint with it.. good luck. hope it helps
bc811 said:thanks for the input...but do u guys have a waxing instruction video? youtube or something like that?
GS4_Fiend said:When you say damp you mean wet it water? I think using QD is better...
Accumulator said:With Collinite 476S I use distilled water. I sometimes use QDs with other LSPs but IMO you need to know that the LSP/QD combo will work OK lest you find yourself with issues.
GS4_Fiend said:What about Natty's Blue then? What you suggest?
