Question on application of Blackfire Wet Diamond
Rand
Since I put on my last application of BFWD I have used Optimum car wax as well as Meguiars Quick wax. If I am going to apply another coat of Blackfire do I need to first polish to remove the spray waxes or will Blackfire bond to the car as is? I have not used any carnuaba wax on it.
Thanks
Thanks
Optimum Wax contains carnauba ;) Most sealants like to go on a clean wax free surface.
I noticed it said the following on the Autogeek website regarding DP Poli-coat Paint sealant - "With most paint sealants, it is recommended that you use a pre-wax cleaner first to prep the paint for the sealant. This step promotes bonding and improves the clarity of the shine. But what if you could achieve the same high bonding and clarity without a second step? That’s what you get with DP Poli-Coat Paint Sealant".
Anyone ever try DP Poli-Coat Paint Sealant without polishing or removing carnauba wax first?
Thanks
