Jul 25, 2004 #1 G galvatron New member Are you using Z6 or anything else to moisten the pad? Also, what type of pads are you using, and are there any techniques that you can suggest? Thanks
Jul 25, 2004 #2 D dternst New member Personally I prefer to apply by hand using either the MF or foam applicator. I reserve the PC for polishes.
Jul 25, 2004 #3 L lammarwell New member I give the PC's grey finishing pad a quick spray with Z6 and then apply 2 coats of Z5 ( with Z6 in between all coats) and then 1 coat of Z2 with the same pad. It seems to work well and is fast but uses more product than applying by hand.
Jul 25, 2004 #4 L LouisanaJeeper New member I actually use less product black finishing pad, speeds 3-4, water (or Z6:water 1:1) to wet pad (not cause it works better than just Z6, but im cheap)
