Question about washing pads, applicators, bonnet, etc
resek
Hi,
I would like to know how you wash and which product you use to wash your Sonus sfx-1,sfx-2,sfx-3 pads, applicators, buffing bonnet, buffing towel, drying towel, etc.
What you can do and what you CAN'T do.
Thanks for the answer.
:2thumbs:
resek said:
Hi,
:2thumbs:
For your foam pads we recommend washing them by hand in cool to lukewarm water with the Sonus Der Wunder Wasche. If they are super dirty you can soak them for 10 minutes then rinse until water runs clear. Squeeze out the excess water and allow to air dry on a plastic drying rack with the Velcro side up so water is not draining and sitting in the Velcro backing. Don’t worry if they don’t look new when you are finished, some staining and wear is normal.
At Sonus, we have created a special detergent specifically designed for washing detailing products out of microfiber and foam detailing accessories. Sonus Der Wunder Wasche is a highly concentrated liquid detergent that a cleaning solution was developed specifically for cleaning microfiber towels. Sonus Der Wunder Wasche is an active cleaner designed to restore microfiber towels, wash mitts, applicators and foam buffing pads to their as-new condition. Der Wunder Wasche is an engineered blend of micro cleaning agents designed to lift, emulsify and suspend waxes, polish residue, oils, proteins, silicones and soil for complete removal in the rinse water.
Hope this helps...
Lynn
Thanks Lynn for your fast comment!
Is there an alternative way if you don't have this "Der Wunder Wasche" ??
Cause even if i would bought it, i wouldn't received it by saturday ...
You could use a liquid soap like dish soap but stay away from all purpose cleaners.
Lynn
Believe it or not, Klasse AIO completely cleaned a stained white Sonus pad that I had laying around... I then washed it out with soap and water. That stuff works wonders!
Awesome Tip, Ill have to try that
