Question about coating
jtford95
Hey people. Not sure about how much coating and what brand do you think would go on my buddy's 98 KentworthIMG_20150822_162232818_HDR_zpsfy1wuzzk.jpg
Wowza, lotsa space! Id think whatever coating you go with youll need AT LEAST a 50ml bottle, or whatever the largest size you can find is. Possibly 2.
Im sure someone on here at one point or another has coated a semi truck and can chime in
I would order 2 x 50 ml Gtechnig Exo. Not to expensive and you will have enough to do 2 costs I think. We're talking can only right. It lasts about 18 months but it is somewhat dependant on wear and tear and maintenance. Perhaps gloss coat as it's very durable.
Just might need 4 tubes for 2 coats.
Thanks for your response. I would like to try something like this but, when it gets washed, the chemical are strong. So, I don't want to spend alot and it isn't going to last any longer than a regular wax / sealant.
The Gloss coat is pretty chemically durable. I have washed my Opticoated cars (I was 2.0) with Ironx foam soap and APC (TAW) without hurting them, and in fact it restored the a lot of beading and self cleaning properties.
For Quick and easy, you could permanon it.
Yeah a coating may not be the right answer if the chemicals used to maintain it are just going to be flushing your hard work down the toilet. Just put a sealant on it would be my route.
I am on the fence so far. Thanks for your responses so far. It was repainted and need wet sanding and compounding. So we are a little ways off. I will look up what two product and see what cost is
Can't tell ya how much coating, but will tell ya a few advil before, during and after.............
