QD between SG applications?
AudiUrLg
I generally apply the Klasse twins every 4-6 months depending on wear. I'm looking for something to renue the glaze when I wash during this time period though. Over even better something to deepen the shine after I apply. Any suggestions of a QD that would work well for this?
Can i apply mothers fx synwax over the klasse ? I was hoping to create a deep wet look over the shine. Just wondering because fx is petroleum distillate with some cleaner & dunno if it will strip the acrylic off.
ps. My klasse has milky solids in them, is it normal ?
If you're applying only after washing, you can try a 1:6 mixture of SG:water.
It's very economical, easy (Spray on, wipe off), and looks as good as if you had just SG'd the whole car. Typically, I could 'finish' the car (after washing) in about 10 minutes with the SG/Water mix.
The great part was that it was topping up the protection after each wash - so although the diluted SG may not have the same durability as SG at full strength, being topped up weekly certainly maintained enough protection to make bird bombs & tree sap come off easily.
I like the following over KSG: FK425, UPP UGE, and the BF QD. All do a little refreshing of the just-sealed effect and I apply one of these after every wash.
But for a *real* refresher, I'd just clay with Sonus green and give it another quick application of the KSG, that's what I do on the MPV every now and then.
