PS Detailed: 2006 Monterey Red Corvette water spots no more
gmblack3
Since 1953 the corvette has been known as "America's Sports Car."
This Monterey Red convertible is no exception. Equipped with Z51 suspension and the M6 6 speed manual, this 400hp vert will move you.
Not only was the clients main concern the water spot etching on the hood and rear deck, he was equally concerned with how much clear coat would be sacrificed while the water spot etching was dispatched with.
I explained to him how its always my goal to remove the minimum amount of clear coat, while ensuring that the defects (water spot etching in this case) are totally removed or to a point where the client is not cursing everytime he looks at his car.
I informed him that I'm one of the few detailers in the country that has a Defelsko PosiTector 200 Series (Advanced) PTG. So I am able to 100% know exactly how much clear coat I am removing from a composite, plastic or fiberglass based panel. I also know how thick the clear coat is. The advanced model can read up to three individual layers.
Some before shots of the water spot etching.
Hood:
Rear deck:
Process:
Wheels cleaned with MWB and various brushes.
Tires and wells cleaned with ARO.
Foamed paint and glass with Zaino Z7 carwash via foam lance.
Sprayed cloth top with 303 fabric top cleaner and allow to dwell.
Washed paint and glass via 2BM sheepskin mitt.
Scrubbed cloth top with fabric brush.
Thoroughly rinsed fabric top.
Clayed paint and glass while still wet with zaino clay and QEW mix as lube.
Electric leaf blower used to remove excess water from all surfaces, wheels and tires.
Final drying done with big blue WWs from CMA. I love these towels.
3x wipedown with straight 91% IPA to ensure all waxes, glazes or sealants are removed from painted surfaces.
The interior was my next area of concern. I wanted to let the fabric top to fully dry overnight. I would start on the paint the next day.
Interior process:
Thorough vacuum using our Dyson DC28.
Mats and carpets spot treated where needed with Folex.
Hard surfaces steamed with my VX5000 steamer.
Hard surfaces then cleaned with 1Z einszett Plastic Vinyl Deep Cleaner "Plastik-Reiniger."
Hard Surfaces treated with 1Z einszett Vinyl-Rubber Care & Protectant "Tiefenpfleger."
Leatherique Rejuvenator Oil applied to leather and allowed to dwell.
The interior was very dusty as the windows where left down in the clients garage for an extended period of time while he was out of country:
Leatherique Rejuvenator Oil applied:
The next day I started on the paint.
I first checked the thickness of the clear using my Defelsko PosiTector 200 Series (Advanced) PTG.
I have found the clear coat on each C5/6 vette that I have worked on to have a total thickness of 60-65% of the total coating thickness. As you can see we have 3.3 mil of clear coat and 2.0 mil of basecoat/other.
The maximum amount of clear coat removed was .10 mil
My process for the water spot etched hood and rear deck where as follows:
Surbuf pad/M105/Festool FEQ 150 speed 5
Orange classic flat LC pad/M205/Festool FEQ 150 speed 5
Black classic flat LC pad/M205/Festool FEQ 150 speed 4
Some progress shots after the surbuf pad step:
The remainder of the paint also had the above steps, but the surbuf pad step was worked at a decreased time due to the medium level of defects.
That ended a long day of paint polishing.
The next day I applied leatherique pristine clean to the leather to remove the Rejuvenator Oil.
Rewashed the car via the 2BM/sheepskin mitt with a mix of Dawn and Zaino Z7 to remove polishing dust and oils.
Aided by my electric leaf blower to remove as much water as possible from the freshly polished paint, I finished drying the paint with clean big blue WW towels. I ensured that I did not get the fabric top excessively wet.
I left the car out in the sun for another hour to ensure the fabric top was dry.
I raised the electric top up and placed 100% cotton towels under the top prior to lowering the top.
I applied 3x of Raggtopp fabric top treatment in alternating light coats. Allowing 30 mins of drying time between coats.
Any painted areas and glass that had Raggtopp overspray on them where cleaned with QEW.
A final Z6 wipedown was done.
I then applied 3x of the following zaino products mixed in a small zaino mixing bottle:
80% Z5pro
20% Z2pro
1 squirt of Z8
5 drops of ZFX.
Tires got Z-16 and wheels got ZAIO.
Rear tips polished with Blue Magic polish and #0000 steel wool.
The client was kind enough to leave a comment on the CF:
Bryan: Many thanks again!! You did an amazing job. I'm glad that we were finally able to get that scheduled. If you are ever asked for references, don't hesitate to give me call.
I can't say how pleased I was with the job and the fact that I asked for a paint polish and Bryan went the extra mile to clean and coat the ragtop, did a wonderful job with the interior and polished up the wheels and exhaust tips. You can really tell that Bryan is definitely one of the best!
Bryan I will see you again next spring after another wonderful summer of long weekend runs!
looks good man. YOu got some good photo skillz. What camera and gear are you using?
Surprised to see that you are not using your PC's
Thank you vtec!
Canon XTi with tamron 17-50mm 1:2.8 lense in fully auto mode. Photoshop used to resize pics, no other tweeking of pics. Sometimes I just get lucky with the right amount of sun.
The Festool FEQ 150 is a R/O. Here I am using it on a black Lexus LS430:
Camaro5Ryan said:
Great detail :D
Thanks Ryan!
Very nice work indeed Bryan. That Vette was in dire need of some quality TLC, and you're obviously the right guy to bring it back to the condition that it deserves. Bravo my friend!
Would you say Its worth it to go out and buy a Festool if I already have a flex 3401 VRG and rotary. I really want a festool but its $500.
Nice work! I really like your interior shot from the passenger side...nice and clean.
I also really like the look and feel of the Festools...but sheesh are they pricey.
Awesome work Bryan! Great write up with excellent pics too! Owner must have been very happy! :bigups
I added the clients comments at the bottom of the original post.
Todd, Thank you very much for your kind words!
For me it very much is. I spend countless hours polishing paint and even though the level of vibration is greatly reduced with newer R/Os like the Megs G110v2, the festool is in a league of its own. They do have a 30 day return policy.
Thank you D Taylor. If I did not think it was worth the $495, I would of sent it back already.
a_guerrajr said:
reall good job.
resutls look very nice.
Thank you a_guerrajr!
Thank you Chad! I just loved your wetsanding writeup on the Impala. :spot
gmblack3a said:
Thank you vtec!
I have heard some very good things about Tamron lenses. Was looking to eventually get one myself for my Nikon if it doesn't sell.
As you mentioned sometimes we get lucky and are able to get those really crisp images depending on the light.
So you like the festool FEQ 150 over your PC?
BigAl3 said:
once again, perfection and another very satisfied customer... :up
Thank you Al! As I pulled up to the airport to drop off the vette to the client, he was just walking out from the terminal. He yelled out, WOW! That is my vette!!! :getdown
I like the Tamron lens for the price. I'd love to have some L glass, but too many projects to be completed around the house. :rolleyes:
I sold my XP PC after I got a G110v2. I really like the G110v2 over the XP PC. The v2 has less vibes then the XP and just feels better in your hands. I can also correct with the v2 at speed 5 where I was always using speed 6 on the XP. After using the XP PC for 6 months, I don't really think its a big improvement over the 7424. For a R/O in the $150 price range, I highly prefer the G110v2. (I have never tried out the new griots R/O)
Then you have the Festool FEQ 150. From what Kevin told me it has a smaller throw then most R/Os, but believe me it still gets the job done without issue. Due to the smaller throw and high quality construction, it has approx half the vibration of the G110v2 IMO. I use it on speed 5 to do all corrections with ease via the KBM. The festool is very loud and I always wear earplugs. Also you can't change out the size of the BP with the Festool.
hmm. thats good info. It seemed loud on all the videos. how is the rotary cut versus the orbital cut? is there a big difference in the two modes?
I tried the forced orbit mode a few times, I just don't care for it. I can do whatever I need in the r/o mode via the KBM.
Show off! Just kidding Bryan oustanding work as always. I enjoyed the paint meter parts in thread. Often those things aren't fully explained and you made a great way of showing it. The vette looks awesome. Thanks for sharing.
d00t said:
Outstanding work, Bryan! Love the color combo.. tan and red is so classy
Thanks Aaron!
weekendwarrior said:
Great job on a beautiful color.
Thank you David!
Thank you Barry!
Deep Gloss Auto Salon said:
Perfection is a wonderful thing isnt it:bigups:xyxthumbs
Superb work as always Bryan...Second to none.
Jason, Thank you very much for your kind words! :thx
